I have a 95 VR6 automat.
I have noticed since a time that the fan has run after I left the car. That is not usual because it's early spring with temp near freezing point. I have also noticed the car have become hard to start, I have to run the starter a much longer time. When car is running I haven't noticed any other problem.
Today the motor was really hot, the warning light for motor temp was blinking. The meter show 120 degreas and oil temp 122. Water level was ok. I was little afraid that something dangerous should happen but I didn't drive so far. I noticed that the hose from thermostat was really hot.
I first thought it could be the thermostat that didn't open, but it isn't an usual problem.
I now have started to wonder if it could be that the motor have an air leek so the mixture is to lean. If the mixture is to lean I think the motor will be warmer. How does that sound? The fact that the car now is hard to start could perhaps depond on to lean mixture.
