Beiträge von MIKKONEN
Scheisse wetter (tomorrow, snow etc
)......my car is now in garage. When it´s over +10C (maybe Sunday), I´ll take it out to sunshine
Then I might snap few pictures.
Hello. Has anyone used services of this company?
Anything to comment
I´m coming in June to Kassel. RPM Tuning Systems is going to install
this kit to my car:
http://www.rp-motorsport.de/glader/g60-leistungskit-2.htm
Also "Überholung" to G-Lader.
http://www.rp-motorsport.de/glader/g60-instandsetzung.htmPlease write in german or english (finnish ;)) , but it´s better that I write in english so you can understand
I was lucky...plastic covers, easy to remove to fit foglight/blinkers.
Looks perfect with Angel eyes. -
Hello! Has anyone had problems installing these?
I´m missing a hole
(under old nebelsw). Clip should go quite away inside, so I´m doing tomorrow an enlargement to bigger hole next to it.
I guess in new models there are no problems, but in my 1991 they exist.
Danke zu beiden. Es funktioniert jetzt tadellos.
http://personal.inet.fi/koti/pasi.mikkonen/plan.jpg
http://personal.inet.fi/koti/pasi.mikkonen/plan2.jpgWhich cabels should I connect to red/black (open) and red/yellow (close) ??
87 , 87A , 30 ???you can also answer in german ....I can read it....but it was better that I wrote in english
http://personal.inet.fi/koti/pasi.mikkonen/plan2.jpgWhich cabels should I connect to red/black and red/yellow ??
87 , 87A , 30 ??? -
Hallo! Ich habe noch einige Probleme mit den Kabeln... hier sind Verbindungen zu den elektrischen anschlussplan. Könnte jemand mir helfen und erklären, welche Farben angeschlossen werden. Danke!!!
http://personal.inet.fi/koti/pasi.mikkonen/plan.jpg -
Hello! Does anyone know about the colors in central locking. I bought this kind of system:
Lock .Now I have to connect it to the right cables....so which color opens and which one shuts?
Thanks,
Pasi Mikkonen
Nokia,Finland -
Only things I could find were:
1AC = ABS
4GF = Windschutzscheibe (Wärmeschutz Verbundglas) grün
8TC = Nebelschlussleuchte (links)
8GC = Drehstromgenerator 65AOthers are still a mystery
Can some one help? What do these codes mean ? Especially the ones down starting from X0A...??
1137 45-3-7028 188 9 27
WVWZZZ50Z MK004978
509 014
CORRADO
118 KW GKAT 5G
PG AYN (Motor & Getriebe)
LY3D XW (Tornadorot & Platin)X0A 1AC 1BM 3FD
1C1 1D0 4KC 4GF
1MG 4KC 1G4 --
8BB 8TC
8FBO 8GC 8U0 1TB 3L3
Danke! -
I have same problem in my 1991 G60. Bentley manual says that the problem is a faulty MFA Vacuum Sensor G55.
Here are some prices from the forum:
357907346 1,2bar VDO ..................109€
357907346A 1,2bar MOTOMETER......87,50€
357907346B 2,0bar MOTOMETER......87,50€
357907346C 2,0bar VDO.................105€ -
Thanks for the info....have compare prices to our local. And also ask which one of those will fit mine. 27.4.-3.5. I will be in Germany...and of course I will visit some VW dealer.
Hello! I´m having problems with consumption readings in my G60. It gives too high values...Bentley manual said that this MFA vacuum sensor might be then broken. How much does it cost in Germany ? And has anybody had similar problems with their cars ??
Pasi Mikkonen
Is there any way to adjust headlights manually ? I changed new reflector into my drivers side headlight. Then I tried to adjust them inside the car....but they weren´t in syncro. So, do I have to take headlights out and "run" motors separately to get them alligned? There are some red knobs in the motors, but I´m not sure what they do.
Thanks for quick answer! One scrapyard has a used one...but some attachment parts are broken (50€). Just thinking that if that one has the reflection-part OK, then I might swap it to mine. I think it comes off if I take motor away and open the screw on other side...maybe
When changing new glasses to headlamps I noticed that "reflectionpart" was burned on drivers side....maybe due to use of too powerfull bulb.
So I´m asking if this "reflectionpart" is sold as part or do I have to buy a complete new/used headlamp (Scheinwerfer) ?? number/price ?
Headlamp is with motor...Danke
Mein Corrado ist jahrmodel 1991 (G60). Scheinwerferglässer kommt aus Schweden. Ich hoffe das ist passend. Hella ist marke in meine original.
Heute fahre ich nach Turku, da ist ein rote G60 (1991) für demontage. (Mit schwarze leder innenstattung). -
Wie viel kostet scheinwerferglas ?
In Finland kostet 45€ stück.
Neue nebelscheinwerfer kostet 95€....und in Deutschland ?
