Anyone know what this is for:
http://www.arz-tuning.de/shop/product_i…0L-16V-VR6.html
And do I need it if ordering the Hartmann cat-back system?
Also where is it supposed to be bolted on?
I know when you installed the Hartmann exhaust system at least at 16V with the new body then you have a problem back at the fuel pump / fuel filter / the tank. One can change a bit because to put with a holder that you can build yourself only then adjusts the exhaust good.Wait whether a driver informs the VR6 drives.
hmmm, does this mean that the hartmann system might be a bad "fit" ?....(problems getting it to fit properly)...
One must unfortunately put the 16V pump, whether one that also has the VR6, I can not say otherwise exhaust suits ask good.Ich once in German.
Passt die Hartmannauspuffanlage wenn man sie beim VR6 verbaut gut ? oder muss man auch etwas abändern/versetzen ? wie beim 16V.
Ok I looked up the problem has been not with the VR6 it may be, however depending on the catalyst length you have the catalyst on the tube to cut something.
dont think so, maybe if you want to put them on a 16v like pstuerm was remarking. but never made my own experience.
i saw you own a vr6 and dont want to go with the dual system exhaust so i think you wont run into any probs. actually those hartmann exhausts fit very well.
Ok, thnx for the info - will order em soon then I guess....;)
Don't forget
You need a double clip to install the exhaust to the catalyst.
You can order this part at your local VW dealer.
Take a look to this part at ebay 280296778597
Don't forget
You can order this part at your local VW dealer.Take a look to this part at ebay 280296778597
ok, so it doesn't "bolt" on to the CAT? - any idea about the VW Part number?
thanks
