In Finland kostet:
pumpe 259,-
geber 126,60,-
In Finland kostet:
pumpe 259,-
geber 126,60,-
Hallo!
Weisst jemand was kostet in Deutschland
1HO 919 651Q (benzinpumpe)
1HO 919 673F (send.unit)
Danke,
Pasi
Hi! I hope someone can help me to solve what it causing my speedometer needle to jump....like when I´m doing actually 90km/h...it can "jump" to 230km/h and of course when it hits 120km/h , rear spoiler goes up.
Could this be connected with Vehicle Speed Sensor ? Do ABS-rings in the rear have anything to do with speed ??
Other thing is consumption readings.....it´s usually showing x 2 more gasoline than I´m actually using. (Vacuum sensor broken ???)
Pasi
(Again, you can answer also in german....I can read better than write :D)
Relay 18 (Load reduction relay) war kaputt.
Everything should be OK, after replacing it.
Grey relay with number 18 (Load reduction relay) is broken. Contacts are loose.
So after replacing it with a new one, everything should work.
Thanks to everybody for help ![]()
Pasi
Schalter für elekt. Recaros bei VW händler kostet 115 € ![]()
(in Finnland).
Ich habe elektrische Recaro sitze montiert und ein (original) kabel mit sicherung verbindet (platz Y1 in Sicherungskasten).
Hier ist ein list was fällt aus:
- Schiebedach
- Scheibenwisher
- Innen gebläse
- Nebelsw.![]()
Reise nach Deutschland 3.6., keine Zeit vergeuden... ![]()
http://personal.inet.fi/koti/pasi.mikkonen/sitze.jpg
You might notice that they are not in same level. Can I fix this somehow ![]()
Konsole. I hope you understand english (quite hard for me to write in german).
I mean those two black "pipes" which are moved by motor. These pipes are not in same line. Left edge of seat is higher than right side, because of these pipes that connect the seat to rails. I think they should be moving in same line when I move the motor ? Is there any way I can make them go in "syncro" without breaking the console ?
Ich habe Recaros aus Ebay gekauft. Habe ein frage:
Wie ist das mit konsolen "klammer". Sie sind nicht gleich rictung. Wenn ich die Sitze montieren, sind Sie schief. Kann ich das modifizieren ??
Diese funktioniert nicht:
- Schiebedach
- Scheibenwischer
- Nebelscheinwerfer
- "Fresh Air Blower" - Gebläse
ABS leuchte ist an.
Bremspedal ist hart.
Kann jemand mir helfen ?? ![]()
Ich habe ein Sicherungskasten aus Deutschland bestellt her.
Die Sicherungen sind OK. "Fusebox" kaputt ![]()
Schiebedach, ABS....anschluss mit Sicherung nummer 4.
Vielleicht muss ich das Auto zu service fahren ![]()
Mein altes Escort (MK5) hat problemen mit fusebox, aber ist dass
also möglich mit mein Corrado ![]()
Was ist los wenn diese drei spielt nicht ? Gibt es irgendwas verbindlich ? ![]()
(Sorry my bad german
I understand quite well german, but writing is more difficult)
Sunroof doesn´t work and ABS & handbrake -lights are ON.
I suspect that there might be something wrong in fusebox ??![]()
I opened fusebox, there was one loose cable with big white connector, should this be connected to somewhere. Also small blue/white loose wire
behind the box. Are these needed ?
1BM ist das Fahrwerk
1BM = ![]()
8FBO = ![]()
I have Sportsitzbezüge, Schattenkaro Platin XV. So just normal.
I have tried to look grey Recaro interior, but no luck. I don´t like the frontseats I have now....Recaro is better for my operated back. Maybe Recaro Style XL. I tried that seat last december in Essen Motorshow, and it was perfect. Price isn´t though ![]()
