Hello again
G60 is the car, lowered -50 mm with Eibach, 9x16 et 15 rimms with 215/40 tires. Does any of you guys know what would be the right amount of Camber angle in the front side of the car? After I installed the the new suspension the Camber was about (-)1,50 degrees per side. It was better to drive that way. Then I had a four wheel alignement test or what you call it? Mirrows were intalled to all wheels and Cambers and other things (caster, toe-in-out )were checked and reset. Cambers are now (-)0,25 per side. Is that too little?? After that the car became more restless. The car wants to go were the tiremarks, groove, are on the asphalt. Toe is set to 0,00m per side, is that normal??
