Can i use a 70mm poellie white my standerd chip???
70 mm poellie
No
No ! You will risk your Engine. In the original Chip are no data for the higher Boost-Pressure. So the ECU will take the max value from the factory Boost-Map for calculating the fuel mixture and that´s to low for your higher Boost. Your Combustion will run too lean and that causes high Temperature
Hi!
Ihr sprecht mir aus der Seele - aber in Englisch
Toby
