What lowering kit would you guys recomend (maintain driving comfort)
  • Any tips on what lowering and/or suspesion kit I should look into getting for a 95 Corrado VR6?
    Currently it sits on original Speedline rims, I might want to be able to have 17" on it, but not sure if that's possible while lowering it?.
    Also I don't want the suspension to get all hard, as the roads around here, well let's just say theyr not the best, so have to be able to drive over a few dumps here and there.......
    Also any tips on where to order from would be nice.
    Also is there any "breaking kit" available, or should one just go with original break-disks etc.
    thnx
  • A thread chassis by Koni, which may be a little tough. Rims in the 17-inch size is no problem. The car is then not so deep. There is a braking system, as far as I know, from Brembo, but it cost quite a lot. You can also brake used by Audi / VW.
    Ok, any tips on where to find em?, and also any experience with the KW kits?, any difference between them ?
    Also will 17" work on a "stock" car, without having to do any mods to it?
