• i got the sls chip and a 68 poellie in my car but in the midrange there is no power(0 to 4000rpm)
    then after 4000 there is more power.What can i do about it.???????
    maybe the theibach chip was a better choise.
  • I hope you have allready adjustet your Ignition as described for the SLS-CHIP ?
    The same with the BYpass-reducer ?
    Below Full-Load you can influence the Power with the CO-Potie. If you adjust the screw, that will effect more rich or more lean Fuel in low and mid load Ranges.
    89er Corrado G60
    83er Pirelli GTI heliosblau
